Forums >> Revit Building >> Technical Support >> Default how to convert autocad blocks (inserts) into components (family instan
Fri, Jun 1, 2007 at 10:18:28 AM | Default how to convert autocad blocks (inserts) into components (family instan
efko
Hello everybody, is there any way to convert autocad blocks to instances of family (created from autocad block definition) - I've got project in autocad, with furniture and other repeating geometry as autocad blocks, I'd like to continue with the project in REVIT, but don't want to reinstert all of the furniture again with REVIT families, and I know, that I'll be changing furniture positions and geometry of furniture definitions as the project advances. That is / is there any way to tell REVIT during autocad import, that block definition AAA is to converted to Revit general family and all of its instances to Revit family instances? (The other benefit would be, that it would be schedulable) Thanks, regards Frantisek Stafek
Fri, Nov 9, 2007 at 5:12:51 PM | Default how to convert autocad blocks (inserts) into components (family instan
NorCalNomad
yes I need to know how to do this also...someone want to help us out...
Exporting symbols as blocks in Autocad
Thu, Aug 1, 2013 at 10:10:00 AM
Create 3D person family
Fri, Mar 13, 2015 at 8:34:29 AM
Cross Platform Conversion
Thu, Dec 23, 2010 at 12:10:42 PM
Help - How to create a Revit toposurface from AutoCAD blocks?
Thu, Aug 5, 2010 at 10:05:09 AM
AutoCAD Blocks Importing
Fri, Sep 8, 2006 at 3:36:38 PM
Page generation time: 0.7588
