Forums >> General Discussion >> Revit Project Management >> Revit Systems Modeling
Fri, Jun 1, 2007 at 8:56:52 AM | Revit Systems Modeling
Timothyp
I am creating a coordination model. I will be using Revit Architecture as well as Revit MEP to model the Architectural, Structural, and MEP systems for the building. Are there any good references as far as setting up a file structure or managing the information. Should I split the information between revit project files based on disipline, or simply model everything in the same model?
 Thanks, Tim
Fri, Jun 1, 2007 at 2:10:49 PM | Revit Systems Modeling
sdbrown
5 Stars: 3 Votes
If you are the only one working on it, I would do it all in one model with worksets for each discipline. However you mentioned Revit MEP, you would want to do that work in that program, therefore that would be a sep project.
eQuest vs Revit Energy Modeling
Mon, Aug 19, 2019 at 4:07:03 AM
How to improve the coordination between precast construction and MEP systems?
Fri, Oct 31, 2025 at 3:46:56 AM
Dealing with plumbing systems
Fri, Aug 31, 2012 at 5:27:33 PM
Splitting Systems by Floor Level
Wed, Jul 10, 2013 at 12:17:57 PM
Where is the systems menu in Revit 2014
Thu, Oct 27, 2016 at 6:19:02 AM
Page generation time: 2.3816
