17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> Walkthrough down stairs
4 Posts No Rating |
I'm having no luck "walking" down stairs in a walkthrough. Has anyone found a solution to this? Thanks.
Jim
Previously, I have been struggled with this issue too. Try to assign your key frame elevation during your lineup of your walkthrough path and not after it. You should be able to travel between 2 levels by then.
Guess you have no luck changing the path elevation from sectional view or property dialogue box, right? Hope this help!
----------------------------------- Life is never easy but nor it should be complex. Just stay simple  |
3 Posts No Rating |
There is a thead about this at AUGI. I had been trying to figure this out for some time and then I stumbled upon that thead and it straightened me out in no time. You should see the amazing walkthrough I did going up some stairs resently (Just amazing).
The trick is to view your walkthru in 3D mode where you can adjust the camera up & down and also adjust the angle of the camera up & down.
JTF_8,
What is the thread's name/ location in AUGI? So I can have a look on it as well as your walkthrough.
Thanks!
3 Posts No Rating |
Thread is listed under Tips & Tricks Posted by Kirky. Thread name is Simple Walthrough
4 Posts No Rating |
Ah, terrific. I was certain I was not the only one struggling with this. Thanks very much for the reply's. I'll go check AUGI and see if I can get the results I need. Will keep this forum posted with my success.
Jim
Walkthrough - Stairs not visible |
Wed, Feb 21, 2007 at 9:39:11 AM
Exporting Walkthrough Trouble |
Thu, Apr 17, 2008 at 8:00:50 AM
walkthrough questions |
Sun, May 10, 2009 at 7:49:41 PM
New to revit and have a question... Re: walkthrough on 2011 |
Tue, Apr 12, 2011 at 6:01:12 PM
walkthrough |
Wed, Aug 1, 2012 at 5:43:43 PM
