Forums >> Revit Building >> Technical Support >> Wall/Gridline Constraints
Thu, May 31, 2007 at 4:56:56 PM | Wall/Gridline Constraints
wiredguitarist
I have a fairly elementary question.  Using a new project I place one gridline.  Then I place a generic 8"Concrete wall using the Location Line set to Core Centerline on the gridline and parallel along its length.  I am now allowed to lock the centerline of the wall to the gridline.  If I change this wall to a Exterior: Brick on CMU from the library it will not allow me to keep the constraint.  I am wondering why this is so.  I desire to have a CMU Brick wall be constrained to gridlines because they are the exterior support for my building.
I am using version 9.1 thanks in advance.
missing gridline
Wed, Oct 9, 2013 at 3:02:09 PM
Wall Resizing-Gridline Problem
Wed, Jan 16, 2008 at 12:41:44 PM
gridline 3D/2D
Thu, Jul 18, 2013 at 11:14:49 PM
Setting Default Wall Constraints
Fri, Jan 5, 2007 at 2:45:05 PM
Gridline bubble problem (Revit 2013)
Mon, Nov 12, 2012 at 3:49:30 PM
Page generation time: 0.8095
