10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> Split Faced CMU model material pattern help???!?!?!?
Ok let me start off saying I know very little on how to create custom hatches/patterns/.pat files. Now I see in ADT 2007 there is a CMU_split_faced.pat hatch pattern that I want to use in my Revit model. I try to create a new custom material pattern in Revit, use the .pat from the ADT split faced .pat file and it says there is no model info in it. How can I make this a model material surface pattern does anyone know how to manipulate the text file (.pat) so that I can use it? we basically have running bond exteriors with banding of split face and non. Anyhelp ASAP would be greatly appreciated.
taken from my blog: 8. How do I change a model pattern to a drafting pattern or vice versa?Edit the PAT file using notepad and add or change the following values:;%TYPE=MODEL for model or;%TYPE=DRAFTING for drafting.You can also set the units with the following operator:;%UNITS=MM to set to millimetres… HTH.
Regards,
Chris.
Again thanks for your help Chris. You know I realized this easy fix after I posted the question and you beat me to the anwer post. =) I am trying to take out the squiggly lines though in the ADT2007 CMU_SPLIT FACE.pat and replace it with a sand hatch. I dont suppose you have the fix for that do you?
Here is a pattern for Split Face Cmu that I made. You are welcome to it.
Hey thanks alot. super close to what I am looking for. do you happen to know how i can easily make the sand pattern a little more dense? thanks a ton again!
I had to play around with the numbers contained in the pattern file to get the correct density I wanted. The smaller the numbers for dash length, space and offset will achieve a denser model pattern. HTH
Great! Thanks alot for your generosity. I will tweak the numbers to get what i need. Thansk again both of you guys.-
split face CMU pattern |
Wed, Jan 28, 2009 at 6:08:54 PM
CMU Wall |
Thu, May 7, 2015 at 12:15:47 PM
CMU Hatching/ Alternate Bands |
Fri, Aug 10, 2007 at 8:09:22 AM
CMU Block pattern problem (2010) |
Wed, Sep 9, 2009 at 2:31:27 PM
What is the best way to hatch a CMU Wall? |
Wed, Nov 4, 2009 at 7:00:29 PM
