29 Users Online (27 Members):
Forums >> Revit Building >> Technical Support >> Question from a Newbie
15 Posts No Rating |
I have a project previously done by someone else outside of our firm that we obtained that I need to make changes to. There is an "Import Symbol: Kitchen Equipment.dwg" that I need to make changes to. Its not a linked drawing. In the properties it shows up as System Family: Import Symbol. Is there a way to make changes to this drawing. It's becoming a pain in my backside trying to figure this out. i hope this all makes sense. I really just need to delete a few lines from the CAD plan and add some new lines. But I cant find any edit options. only Explode and Partial explode. Thanks for any help.
No you can't you'll have to get your hands on the original DWG drawing and modify it in autocad. What you can do is turn everything off in teh view except the dWG then export to dwg and edit and relink. If its not much work you can do a masked region or solid no hatch fill to white out the area you need to fix,then draft over.
its a very small amount of work. the masking option sounds like it would work but would it reflect on all the drawings, or do I have to go through one by one? Thanks for the response by the way.
Extruded roof - fascia - (Newbie question) |
Wed, Jul 5, 2017 at 8:12:43 PM
13
Newbie Grid Question Revit 2008 |
Tue, May 15, 2007 at 1:48:03 PM
Having problems with my Project Browser, a newbie question |
Mon, May 2, 2011 at 12:38:33 AM
newbie.. |
Sun, Nov 28, 2010 at 2:33:02 AM
Newbie here...quick siding question |
Sun, Feb 17, 2008 at 3:24:25 AM
