Forums >> Community >> Newbies >> non orthagonal dimensions
Thu, May 31, 2007 at 12:13:02 PM | non orthagonal dimensions
BarryS
Hi All,  I have been trying to place non orthagonal dimensions with no success when measuring from wall joins.  The tutorial has a TIP that you highlight the joined wall and tab through until a perpendicular appears at the join.  When I tab the prefer snaps highlight but not one that enables me to dimension on an angle--- I can accomplish my goal by drawing reference lines perpendicular to the angled wall and measuring between them--- there must be a direct way to do it----any help wouldbe appreciated--- I can't believe I can't figure this out.--Thanks All
Thu, May 31, 2007 at 12:46:12 PM | non orthagonal dimensions
sdbrown
5 Stars: 3 Votes
Are you using the non orthagonal dim tool or the standard?  Basically you should be able to select the angled dim tool, then tab on the endpoint of the wall until it highlights the end point, then drag to the other end of the wall and tab until you get that endpoint.  Or you can draw a line perpendicular to the wall, then dim from that to the endpoints, then remove the witness line to that line and delete.
Fri, Jun 1, 2007 at 7:41:18 AM | non orthagonal dimensions
BarryS
Thanks Sd brown----  your suggestions worked----  I appreciate all the help --- someday I won't be a novice---thanks again
align text non orthagonal
Mon, Mar 18, 2013 at 7:36:52 AM
How does one create non orthagonal mullions?
Tue, Dec 5, 2006 at 4:36:18 AM
Curtain wall vertical mullions won't go vertical
Tue, Feb 1, 2011 at 3:41:42 PM
Elevation Shadow Study
Sun, Sep 20, 2009 at 8:51:59 AM
Orient a view perpendicular to a work plane
Sun, Feb 22, 2009 at 11:53:39 AM
Page generation time: 1.6628
