Forums >> Revit Building >> Technical Support >> Cuts in Wall Sweeps
Thu, May 31, 2007 at 12:03:53 PM | Cuts in Wall Sweeps
Leslie
First Issue....We have created a canted stone sweep on the exterior of our building. I checked the cut by inserts box and the sweep nicely cuts around my windows & doors but does not set back the distance of the window/door trim. In the past I have used voids which provides blue dot grips that can be adjusted...no such luck now. Any suggestions on how to cut the sweeps back at selective places???
Second Issue...There are breaks in our sweeps where we did demo work or the sweep passes over existing verses new wall sections.
attached is image
Wall Sweep Overlaps window frames and cuts (some not all)
Mon, Jun 22, 2015 at 8:09:40 AM
Angling Wall Sweeps
Wall Cuts
Thu, May 22, 2008 at 6:22:37 AM
Walls with automatic wall sweeps
Fri, Aug 31, 2012 at 3:58:55 AM
Outlets and Wall Sweeps
Wed, Feb 29, 2012 at 9:39:46 AM
Page generation time: 1.8666
