Forums >> Revit Building >> Technical Support >> Interior Elevations
Wed, May 30, 2007 at 11:53:54 AM | Interior Elevations
superelboogie
Ok...Why is thatwhen I make an interior elevation in my Floor Plan Callouts, thatit automatically snaps to the slab floor thickness? And if Im doing a Second floor of a hose it snaps the the first floor levels? whydoesnt it snap to the nearest levels in my veiw?
Help me please! its really annoying!
Thu, May 31, 2007 at 12:55:34 PM | Interior Elevations
sdbrown
5 Stars: 3 Votes
You may have created your view wrong. It should place the elevation at the level your are placing it up to the level above. I've seen new users copy a floor plan and rename it the next level up and adjust the view range, this is NOT the way to create a new floor plan of an upper level and will cause the issue you describe.  Also you can check the workplane of the view, by clicking workplane and making sure it is the level youre on.
Thu, May 31, 2007 at 3:33:40 PM | Interior Elevations
superelboogie
I created the view as a new level. Then I made a floor plan callout to go around the area for an enlarged floor plan. And then I place the Elevation Marker. The View Plane is set to the right level. But it still for some reason snaps the elevations top and bottom lines to whats below it (on the first floor it just goes 4" high on the top and bottom of the concrete slab.)
Its so annoying and time consuming to go through and stretch out each veiw. Im not sure what the deal is! BLAH!
Thu, May 31, 2007 at 4:20:41 PM | Interior Elevations
Sounds like you did exactly what sdbrown warned you about. From the View menu, did you select floor plan then choose the second floor level?  If you do not have a second floor level in your elevations, then you need to establish that first.
Edited on: Thu, May 31, 2007 at 4:29:26 PM
Mon, Jun 4, 2007 at 1:44:42 PM | Interior Elevations
superelboogie
it doesnt matter what level or  floor plan callout I place the elevation on, it always snaps to the floor or the level below it. The floor plans were all made correctly and the veiw plans are set right. Any other ideas?
Problem with Interior elevations
Fri, Feb 13, 2015 at 1:51:29 PM
interior elevations
Wed, Apr 11, 2007 at 9:43:04 AM
Interior Elevations Referencing Detail Numbers
Sat, Oct 13, 2007 at 11:04:39 AM
Interior Elevations
Mon, Jan 23, 2006 at 5:42:42 AM
rotating interior elevations
Fri, Mar 17, 2017 at 6:52:25 AM
Page generation time: 3.7151
