10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> Topo not visible
V9.1, The topo I created from import instance (just like the 5 times I have done it before) this topo cannot be seen in any view but section (incl. site and 3D) , as well, the cad file for roads in not visible. I have checked phases, view range, crop regions, and nothing to be found. The site is at 500 ft. Any thoughts? Thanks
I answered my own question. The survey CAD file that I imported from had the origin (0,0) based at the equator, therefore the topo surface was created 5000 kilometers from the Revit origin making it impossible to find. When creating topo from instance, butcher up the CAD file, make your own CAD file, take only what you need, contour lines, road lines etc. locate the objects near 0,0 file link into Revit, create the topo surface, you may have to adjust the view ranges, my site is at 500’. When I am finished the roads I will link all the houses to the site. If I am successful I will post an image. Cheers.
lines on topo surface |
Wed, Aug 3, 2011 at 8:37:21 AM
Topo Lines part 2 |
Tue, Feb 28, 2012 at 10:05:01 PM
topo depth |
Wed, Nov 7, 2012 at 2:17:31 PM
14
Invisible Topo |
Mon, Jan 27, 2014 at 10:25:29 AM
Drawing lines on 3D topo |
Thu, Sep 22, 2011 at 9:29:47 AM
