Forums >> Revit Building >> Technical Support >> Plan Range - displayingn duplicated views
Thu, Jan 6, 2005 at 12:53:03 AM | Plan Range - displayingn duplicated views
Osir
I create plan range boxes to show windows that are above or below the plan cut line. However, I've noticed that a plan range created on one plan view does not show up on a duplicated plan. I have looked around in visibility settings, to no avail. Do I need to copy the plan range boxes to the new views in order to get them to show? I thought that using the 'duplicate view with detailing' may create new views with the plan ranges included, but want to make sure there is not a way to do it for existing plans. Post edited on 2005-01-06 00:54:40
-IOeser
Wed, Aug 1, 2007 at 8:45:02 AM | Plan Range - displayingn duplicated views
grmorris
Since the original post is almost 3 years old, I'm assuming that Osir, discovered an answer for this.  I don't know if there is another way around it, but what I've done, that has worked for me so far, is after duplicating the view, I go back to the original, select all my plan regiions, and I "copy to clipboard", switch back to the duplicated view and "paste aligned".  It's a few extra steps than maybe it should be, but it could be a lot worse.  And it only takes a minute.
can't use duplicated views as underlay
Wed, Oct 24, 2007 at 4:08:29 AM
Duplicated view - perset
Fri, Jun 15, 2007 at 10:49:53 AM
area plan from duplicated floor plan
Wed, Jun 3, 2009 at 8:38:26 AM
Sections lines not visible in certain plan views.
Wed, Dec 14, 2005 at 11:30:15 PM
plan view range
Mon, May 11, 2009 at 4:34:26 PM
Page generation time: 2.5399
