Forums >> Revit Building >> Technical Support >> Ceiling Tiles
Tue, May 29, 2007 at 3:12:58 PM | Ceiling Tiles
AAbruzzo
Does anyone know how to edit a ceiling system.  i currently need a 2' x 2' grid panel system.  i am having problems trying to obtain this family.  Also, how do you rotate an existing grid or get it to go in the opposite direction
Tue, May 29, 2007 at 3:17:35 PM | Ceiling Tiles
sdbrown
5 Stars: 3 Votes
You just need to click the ceiling tool>then in the properties>click edit new duplicate, then modify the system to use a material that has the 2x2 pattern. To create a 2x2 pattern you need to go to the fill patterns dialog box and click Model>new> cross> enter the dims you want.  If you want them all rotated 45 you can do that here. Or if its just a few once the ceiling is in place you just tab to select a line of the pattern then click rotate.
How to create a custom compound ceiling?
Thu, Nov 5, 2009 at 12:53:14 PM
How to make a Detailed Ceiling
Wed, Mar 25, 2015 at 8:53:41 AM
3D Roof Tiles for temple
Sat, May 15, 2010 at 6:55:41 AM
Scheduling # of Floor Tiles
Thu, Oct 6, 2011 at 6:51:01 PM
how T-BAR with no Tiles
Thu, Nov 27, 2008 at 12:47:50 PM
Page generation time: 0.2269
