Forums >> Revit Building >> Technical Support >> How to make doors flippable in family?
Tue, May 29, 2007 at 8:31:20 AM | How to make doors flippable in family?
jmqrsq
5 Stars: 3 Votes
Basically I have a single door peice of casework that I want to be able to check or uncheck whether its a right handed swing or a left handed swing. How can I incorporate this into the family as a parameter of some sort so all i have to do is click the flip icon and the door will automatically turn off the right hand detail lines/door handle and make the left hand version show up and vice versa? Is it even possible? Sorry if i am not making myself clear enuf. Thanks in advance
Tue, May 29, 2007 at 8:38:57 AM | How to make doors flippable in family?
jmqrsq
5 Stars: 3 Votes
oh and sorry, i want to do this in one family as i know i could do two families to accomplish this. ie. RHcase and a LHcase....... I want just case with toggles for RH and LH. Thnaks again
Tue, May 29, 2007 at 11:09:49 AM | How to make doors flippable in family?
I'm not sure what you are asking.
When you create a family, you can add the flipper to the family.  That will flip all elements including model elements and drafting/detail elements.
Tue, May 29, 2007 at 2:02:47 PM | How to make doors flippable in family?
jmqrsq
5 Stars: 3 Votes
You can add flippable options to ANY family? How do I go about that?
Tue, May 29, 2007 at 3:19:08 PM | How to make doors flippable in family?
sdbrown
5 Stars: 3 Votes
In the family, look at the tools on the left, there are control arrows, chose the type you need, ie left and right, front / back.
Wed, May 30, 2007 at 7:34:40 AM | How to make doors flippable in family?
jmqrsq
5 Stars: 3 Votes
Thanks. Now is there a way to make a parameter that would let me have LH and RH options that would schedule and model correctly?
Wed, May 30, 2007 at 3:56:51 PM | How to make doors flippable in family?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I don't believe what you are trying to do is possible using the flip controls from what i understand...
You are loading nested doors families into a casework family and then loading that into a project correct?
Those flip controls you add to the door family will not persist through the nesting process.  That is, from inside the host family you'll be able to flip them but once in the project you won't have access to them (i think i don't have revit in front of me to check atm).
What I would do (which will also work better for scheduling), is in your casework family add "family type" parameters for the family category of your doors.  This gives you a drop down and allows you to select from all families of that category loaded into the casework family.
Probably sounds a little confusing so I'd suggest you use this coupled with the revit help on how to create these parameters.
You'd also need to set the door families to be "shared" in their family category and parameters settings in order to have them be individually schedulable.
HTH.
Regards,
Chris.
Wed, May 30, 2007 at 8:18:58 PM | How to make doors flippable in family?
jmqrsq
5 Stars: 3 Votes
thanks chris. maybe you could help me better understand the "shared" family category setting? like what does it do exactly? i am one of three people in my firm charged with the task of converting our office from autocad to Revit. We have had our first two projects go out on the streets using it although we had a LOT of acad linked files. My point is I am still learning Revit as I go myself and any info you can spill to me would be appreciated. Basically what you said is what I had hoped for, checking a box in instance parameters to determine how the swing is graphically represented all teh while making it a schedulable parameter somehow.
Wed, May 30, 2007 at 8:23:48 PM | How to make doors flippable in family?
jmqrsq
5 Stars: 3 Votes
a lil more background wouldnt hurt..... we have not ventured into the realm of nested families. we all werent exactly sure how or if they even worked. If i am understanding correctly, we can create the cabinet doors as a family (ie, - cabinet LH.rvt and cabinet RH.rvt) and load those into the cabinet host family (ie. - cabinet.rvt). am i understanding that correctly? I am just not sure what the shared category gives me and what that exactly means. Sorry for my ignorance and extremem thanks for the help =)
Flip Controls in Nested Families
Wed, Jan 16, 2008 at 1:20:13 PM
Problems Changing Colours Of Doors!
Wed, Jul 1, 2009 at 3:24:18 PM
REVIT DOUBLE DOORS
Wed, Apr 23, 2008 at 3:23:50 PM
doors opened in 3D views
Wed, Sep 27, 2006 at 9:20:29 AM
how to open family-doors in 3D?
Fri, Sep 22, 2006 at 1:12:30 AM
Page generation time: 2.3305
