Forums >> Community >> Newbies >> Showing High Windows Cut In Plan
Mon, May 28, 2007 at 2:42:34 PM | Showing High Windows Cut In Plan
heleads
I have a high window whose sill is higher than my cut plane and higher than the top of my doors.  Is there any way to force a window to show up as though it is cut without having to globally change the cut plane. If I change the cut plane in order to see the window, I loose viewing my doors in cut view.
Mon, May 28, 2007 at 3:09:47 PM | Showing High Windows Cut In Plan
heleads
I found my answer.  Under the View bar, select Plan Region and draw a box around the high window, then set the properties of the Plan Region box to set the cut plane where I want it.
high windows and cut plane
Mon, Mar 19, 2012 at 10:15:29 AM
Showing Windows Above
Wed, May 24, 2006 at 7:35:10 AM
Cheating a Floor Plan Cut
Mon, Jul 26, 2010 at 5:53:23 PM
Showing windows on the floor plan
Sat, Feb 28, 2009 at 7:07:23 AM
high windows in plan?
Thu, Apr 27, 2006 at 8:30:11 AM
Page generation time: 1.6351
