14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Door Number Memory
I know this is a bit anal, but its driving me nuts. I'm setting up a template and noticed when inserting doors - the program remebers all the previously inserted door numbers though there are no previous door in the project / template (it starts numbering from 15 instead of 1... the next time I go into Revit it will probably start at 25 for example). I have tried purging my door family and reloading it - doesn't work... Any help would be great! Dan
If you want your door numbering to start at 100, then in your template place a door, give it a number of 99 then delete the door. When you start a project with the template, then your first door will have a number of 100.
Thanks. That was easy enough.
2 Posts No Rating |
is there any way to reset the count to 0??
----------------------------------- AH |
Did you try plazing a door and numbering it 0?
2 Posts No Rating |
Just after you told me and it works ,,, thanks a lot WWHub
Door Tag Parameter-Need it to be the door opening number, not the door type..... |
Thu, May 7, 2009 at 4:09:39 PM
Door Number on two sides of Door Schedule |
Tue, Feb 26, 2013 at 10:17:17 AM
Adding Room Number to Door Tag |
Sun, Jun 23, 2013 at 9:14:46 AM
Door Schedule |
Tue, Jun 12, 2007 at 7:29:31 AM
Door Schedule - Room number on 1/2 floor |
Mon, Jun 18, 2007 at 1:25:23 PM
