15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> Materials
27 Posts No Rating |
Hi, I'm trying to indicate polished blockwork which courses at 275mm. I have made up a materail with a surface pattern using a fill pattern with what i thought was the correct distances apart. However, this worked on my elevations at 1:100 but not a section at 1:50. Is it possible to create a fill pattern which will stay constant no matter what the scale is? cheers marc
sounds like you have used a drafting pattern instead of a model pattern. I don't know many that use the drafting pattern, though there is uses for it. If you can't find a similar model pattern, you can edit the hatch file to make it a model pattern. Check your help file for that, it's pretty simple.
cool, that work a treat. Just 1 more question! How does revit determine the setting out point of these materials? Is there a way to use like a snap base point? thanks for your help
I'm not sure what you mean by setting out point. If you are trying to position your hatch a certain way, you can use the align tool for your hatch lines. Click "align" then position it over one of your hatch lines and if it doesn't highlight, hit tab a time or maybe two and it will highlight.
Adding materials into Revit's materials files |
Thu, Jul 22, 2010 at 1:54:48 PM
Missing Materials |
Wed, Jun 19, 2013 at 2:22:26 PM
Converting DWG materials to Revit Materials |
Thu, Sep 13, 2012 at 3:50:29 AM
replacing materials in multiple family files? |
Wed, May 6, 2009 at 7:13:40 AM
Revit Custom Materials Rendering Objects invisble |
Mon, Mar 14, 2011 at 10:42:55 AM
13
