Forums >> Community >> Newbies >> Family Help Please! 'Labeling this dimension would overconstrain the sketch.'
Wed, May 23, 2007 at 7:56:59 PM | Family Help Please! 'Labeling this dimension would overconstrain the sketch.'
rsampat
I am following the Revit Tutorial in the Help Menu for Family Creation. I followed along, step by step and when I tried to add a Label parameter to a dimension, this error appeared 'Labeling this dimension would overconstrain the sketch.' I don't know what i am doing wrong. Any advice would be appreciated. thanks.
Wed, May 23, 2007 at 8:27:06 PM | Family Help Please! 'Labeling this dimension would overconstrain the sketch.'
framerman
4 Stars: 13 Votes
that error happens when there's already another dimension attached to your constraints or if something is locked. You have to check all the views for dimensions to the constraints you are trying. There could be one already in the family.
Fri, Jan 16, 2009 at 5:43:36 PM | Family Help Please! 'Labeling this dimension would overconstrain the sketch.'
velvetseas
I'm having the same issue.  I have 2 dims on the width of the door, and I'm assuming I am getting the error because I should only have one on the door.  However, I can't delete either of the dimension lines.  I don't think they are locked to anything or vice versa.
Sat, Jan 17, 2009 at 6:53:48 AM | Family Help Please! 'Labeling this dimension would overconstrain the sketch.'
4 Stars: 205 Votes
Yeah, use only one dimension with parameter to control that...
Fri, Jan 23, 2009 at 7:31:38 AM | Family Help Please! 'Labeling this dimension would overconstrain the sketch.'
velvetseas
The problem I'm having is that I can't delete either dimension.  The program won't let me.
Wed, Jun 10, 2015 at 9:18:40 AM | Family Help Please! 'Labeling this dimension would overconstrain the sketch.'
andriusv
Delete parameter then, associated with that dimension
Labeling this dimension would overconstrain the sketch. ??
Sun, May 3, 2009 at 11:14:09 PM
Change length of dimension, and parts of family
Thu, Nov 16, 2017 at 8:27:51 AM
'Out of Memory' pop up
Tue, Sep 6, 2005 at 3:16:07 PM
Window's dimension don't show up in the window schedule
Fri, Aug 17, 2012 at 1:34:43 PM
Stacked Dimension Text (Prefix/Suffix)
Fri, Jan 27, 2006 at 6:21:26 AM
Page generation time: 1.2278
