30 Users Online (28 Members):
Forums >> Revit Building >> Technical Support >> roof fascia
Using revit architecture 2008. When using the host sweep tool to place fascia, how can I get the fascia placed under the roof sheathing?
Try editing the profile used so that it is on the other side of the reference plane in the family. You might have to type VG and put a check mark under reference plane visability under the annotations tab for it to show up. If you are trying to put it under the roof, just make sure you set your rafter cut to 2 cut plumb and set the fascia depth to 0" or 1/32" so your fascia doesn't interfere with your roof. If you are talking about gable ends, well that's a whole new post!
How to miter a fascia on a sloped roof? |
Fri, Aug 24, 2012 at 7:48:23 AM
Roof fascia curves in plan and elevation |
Sun, Dec 13, 2009 at 1:40:44 PM
Roof Fascia On Negative Sloped Roof |
Wed, May 15, 2013 at 9:47:35 AM
roof fascia |
Fri, Jul 27, 2007 at 1:29:36 PM
Adding fascia to curved roof. |
Mon, Dec 13, 2010 at 9:21:59 AM
