Forums >> Revit Building >> Technical Support >> cut symbol on stairs
Wed, May 23, 2007 at 11:22:58 AM | cut symbol on stairs
terealva
Is there a way to change where the cut on the stairs is done?
The building that I'm working on has a part at level 720' and another one at level 722'. When I show this as a whole floor plan my stairs are being cut at different locations. So the stairs that are related to level 722' are just showing about 3 steps and the stairs related to level 720' are showing about 6 steps. I would like them both to show the same amount of steps.
Is there a way to get around this?Thanks,Terealva.
Sun, Dec 4, 2011 at 4:52:39 AM | cut symbol on stairs
FrankyDHalliday
FrankyDHalliday Avatar
3 Stars: 2 Votes
Is either adding a plan region and changing the cut height or simply in the properties pallette for that view changing the view range parameters going to solve your issues?
Dr. Zaius: Ah, yes - the young ape with a shovel. I hear you're planning another archeological expedition. Cornelius, a friendly word of warning - as you dig for artifacts, be sure you don't bury your reputation.
Sun, Dec 4, 2011 at 8:21:55 AM | cut symbol on stairs
I think you answered your own question - plan region.
Stairs and plan regions (cut height)
Mon, Apr 21, 2014 at 10:22:57 AM
2013 stair path symbol for component stairs displays differently
Thu, Feb 6, 2014 at 3:03:50 PM
Revit 2013 - Cut Wall under stairs.
Thu, Oct 18, 2012 at 3:23:10 AM
Plan Region & stairs
Thu, Jun 18, 2009 at 1:28:36 PM
Stair - Cut Profile
Wed, Sep 14, 2011 at 1:36:18 AM
Page generation time: 5.9510
