16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> Callout not showing in parent view
This is quite strange to me - In my GA plans any callouts created are not visible. I have checked visibility settings, its not hidden on scales courser than X, its not hidden in the specific view....... I can see no reason whatsover for the callouts not to display. On other drawings they display fine! A colluege of mine has experienced the same problem on another project Another thing, Ive got columns within partywalls which displays fine in normal plan views, but in callouts it seems like the columns are "behind the wall"- not showing. The columns are RHS's and are Structural columns - not the model element ones. We're using 2008 Any ideas? Edited on: Wed, May 23, 2007 at 9:47:02 AM
Edited on: Wed, May 23, 2007 at 9:47:48 AM
Anyone?
16 Posts No Rating |
I'm having the same problem. I turned my crop region off and the callouts became visible, however I need my crop region to be on, so I don't know how to rectify the problem. If you've figured it out, please let me know how.
If by turning your crop region off displays the callouts, my guess is that your Annotation Crop is cropping the callouts.
Annotation Crop isn't on.
Its a glitch in the earlier versions of 2008 - as far as im aware it happens when a project gets upgraded. To fix it just downlad the latest version from autodesk and install! ;D
Changing Elevation Parent View |
Tue, Nov 9, 2010 at 4:35:05 PM
Detail Callout Bubbles and Dependent Views |
Thu, Aug 12, 2010 at 6:51:10 AM
Parallel sections show up in an elevation view |
Sun, Nov 22, 2020 at 12:07:40 PM
13
View Reference tags in parent view disappear when viewing the parent sheet |
Fri, Nov 6, 2009 at 3:32:26 PM
Callouts Disappearing |
Mon, Oct 29, 2007 at 9:47:40 AM
