Forums >> Revit Building >> Technical Support >> moving a project
Tue, May 22, 2007 at 11:48:31 PM | moving a project
shalesie
peoples....
say hypothetically i had to move the location (as in siting) of my project.... how would one do that without having to ungroup all of my 150 groups...
our original survey wasn't in world coordinates and now the project team want to change it to WCS... easy in bloody autocad....
your help would be appreciated...
Wed, May 23, 2007 at 12:12:25 AM | moving a project
puzzle
4 Stars: 10 Votes
Will your project north be the same? If so I would use Rotate True North. This way you really don't have to move anything.
Macca
Sunshine Coast
QLD Australia
Wed, May 23, 2007 at 12:15:59 AM | moving a project
shalesie
I still have to move the whole project because it isnt positioned correctly... I will have a crack at the whole project and true north issue once i move the job....
Wed, May 23, 2007 at 2:09:09 AM | moving a project
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Providing you have documented the project in the correct orientation as per how you want to document it:
 Just rotate true north as appropriate.
Use "relocate project" to set eastings and northings correctly and elevation.
My projects are always linked into a separate site plan so i can easily move them about.  If this is not the case i suggest you copy the site data into a clean file and link it back in.  You can also do this by grouping it and converting the group to a link.
HTH.
Regards,
Chris.
Moving Whole Pluming Plan
Wed, Jan 16, 2008 at 9:22:04 AM
Moving project to align with Revit Structural File
Mon, Apr 22, 2013 at 7:22:12 AM
Roomtags keep moving in wall sections
Tue, May 8, 2007 at 6:39:49 PM
moving project model to the correct elevation per survey???
Tue, Mar 10, 2009 at 12:06:32 PM
Revit 2014 Crashes When Moving Staircase
Thu, Jan 14, 2016 at 3:26:47 AM
Page generation time: 0.7566
