16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> Gable End Fascia
3 Posts No Rating |
Beginning Revit user here-- When creating a simple gable end pitched roof, the slope defining walls cut the fascia as requested in the 2 cut-Square fascia box (ie 2x but, the gable ends remain at the full thickness of the roof structure making the fascia profile not fit. Anyone willing to give me a clue?
3 Posts No Rating |
Sorry, saw request above -- I'm using revit 9.1
As well as setting this option you also need to set the dimension for how much is to be square cut.
Regards,
Chris.
3 Posts No Rating |
thanks very much for the quick reply. I must be missing something very simple. I have of course set that number to 0 7 1/4" because the lower fascia is cut correctly. it's the gable end that stays at 12" That number is a setting for that entire particular roof correct?
roof fascia |
Fri, Jul 27, 2007 at 1:29:36 PM
roof fascia mitre |
Sat, Mar 14, 2009 at 3:25:46 AM
Gable end of Roof |
Sat, Sep 9, 2006 at 5:31:52 PM
Creating Eave overhang |
Fri, Feb 18, 2005 at 11:05:02 PM
gable returns |
Thu, Jul 15, 2010 at 10:37:11 PM
