Forums >> Revit Building >> Technical Support >> Renovation Wall Suggestions
Tue, May 22, 2007 at 9:06:55 PM | Renovation Wall Suggestions
rkitect
rkitect Avatar
4 Stars: 29 Votes
I'm finding myself doing a lot of basement renovation projects which involve taking as-built drawings and creating a set for renovation construction.  In most cases, the basement is unfinished stud framed walls.  So the walls in my Existing phase are all bare stud wall types.
Now when I want to do new construction walls, I usually just want to skin the walls with gyp on each side.  I have made a wall type with just gyp on each side, but I was wondering how other people go about doing something like this.  It seems like you should be able to say this wall is Type A in existing phase and Type B in new construction phase.
Thanks for you input!
Wed, May 23, 2007 at 12:19:37 AM | Renovation Wall Suggestions
puzzle
4 Stars: 10 Votes
With do alot of renos and have a wall type for each phases. The existing phases is a wall with no fill pattern & the proposed is wall with solid fill pattern. Have a typical legend in the template for the wall types.
Macca
Sunshine Coast
QLD Australia
Wed, May 23, 2007 at 8:23:18 AM | Renovation Wall Suggestions
rkitect
rkitect Avatar
4 Stars: 29 Votes
I think, based on your answer, I need to clarify my question:
I'm not concerned with how to graphically differentiate between existing and proposed phases.  That I can do.  I'm trying to figure out the best and most efficient way to add the layers of gypsum to the existing walls so that is reflected in the proposed phase drawings.
Interior Renovation Project in Revit... worth it?
Mon, Mar 10, 2014 at 12:45:28 PM
Best Practices: Renovation Modeling
Thu, Jun 5, 2014 at 12:17:44 PM
Phasing vs materials...Who is the boss when it comes to graphic overrides?
Mon, Nov 12, 2012 at 9:07:55 AM
Suggestions on presenting revit to boss and co-workers
Tue, Mar 16, 2010 at 12:26:48 PM
Separation line (renovation and new to built), I AM IN NEED...
Tue, Dec 29, 2015 at 7:10:37 AM
Page generation time: 2.0074
