13 Users Online (11 Members):
Forums >> Revit Systems >> Technical Support >> I can not Get my device to attach to the ceiling on a linked architectural file
9 Posts No Rating |
I am using Revit MEP 2008. I have made a projector family and it gives me the NO symbol when I try to insert it into the ceiling plan of the linked architectural file. Any help, I have attached the projector family I created. Thanks
I haven't been lucky enough to be involved with much interdisciplinary collaboration on revit yet. However, I'd imagine you'd need to use the copy/monitor tool on the ceiling to create a linked duplicate of the ceiling in order to host your projector.
Regards,
Chris.
9 Posts No Rating |
I am not sure if that is it, The stock fixtures (light fixtures) connect to it just fine. The projector which I made from scratch will not. I eill try the copy/monitor tool again to make sure I got the ceiling level though.
Many if not most of the stock fixtures in MEP are workplane based. This means that they do not need a 'host' to attach themselves to, just a plane which can be in the linked file. Your projector is 'ceiling' based which means that you need a physical ceiling in yur model in order for the projector to be placed since it needs the ceiling as a 'host'. I was able to place your projector just fine into a ceiling. Your answer may be to create a 'work plane' based version of the projector. The workplane based family is the default mode that should be used for all MEP content for this very reason.
Tom www.reviteer.com http://twitter.com/Reviteer |
Light fixture does not host to ceiling |
Mon, Feb 24, 2014 at 7:14:24 AM
Linking RCP to main architectural model |
Tue, Aug 5, 2008 at 2:52:30 PM
GETTING EXIT SIGN TO MOUNT IN CEILING |
Mon, Jan 25, 2010 at 10:01:23 AM
Attach MEP lights to Arch Grid |
Tue, Feb 9, 2021 at 8:26:08 AM
Linked Revit Model Sheets |
Fri, Apr 5, 2013 at 12:04:28 PM
