Forums >> Community >> Newbies >> cropping viewport on sheet is cropping my floor plan!
Tue, May 22, 2007 at 2:10:17 PM | cropping viewport on sheet is cropping my floor plan!
rsampat
I am trying to create enlarged plans and elevations for the kitchen. How can i crop the floor plan down to the kitchen on the sheet without effecting the actual floor plan. I have tried checking off the crop region and crop region visible boxes. I modified those on the sheet, but when i went back to my floor plan, it was cropped also. Does this mean that I have to create dupicate views for specific sheets? (i hope not)... any advice would help, thanks!
Tue, May 22, 2007 at 3:51:12 PM | cropping viewport on sheet is cropping my floor plan!
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Okay, I think you may still be thinking it AutoCad way's here.
Generally you would create a "callout" (accessible from the views tab) of the kitchen.
However, you can also duplicate the view and crop it as necessary.
Unlike autocad you are working with a model and your floor plans/elevations/callouts/sections/details are just various views of the model.  Duplicating the view does not mean you have twice as much to co-ordinate (unless you have drawn all the kitchen with detail lines, in which case group the linework and then paste it into your second view).
Regards,
Chris.
Views on sheets cropping eachother
Fri, Oct 23, 2015 at 9:27:51 AM
A serious error has occurred. It is strongly recommended that you use Save As to
Fri, Oct 3, 2008 at 7:38:07 AM
cropping region acting weird
Wed, Jul 16, 2008 at 3:15:20 PM
Crop Region not cropping all info
Thu, Jul 27, 2006 at 10:33:17 AM
cropped section views??
Tue, Jun 13, 2006 at 10:49:09 PM
Page generation time: 2.2184
