Forums >> Revit Building >> Technical Support >> Visible floor lines??
Mon, May 21, 2007 at 3:31:58 PM | Visible floor lines??
CND1
Can someone tell me how to turn-off the horizontal lines of the floor structure, when viewing the exterior elevation of a 2-story house. They are visible from the exterior elevations & 3D view.
Thank you
CND
Mon, May 21, 2007 at 3:39:21 PM | Visible floor lines??
TJKENNEDY
3 Stars: 2 Votes
In Visibility/Graphics, uncheck the floor catagory.
Mon, May 21, 2007 at 3:57:54 PM | Visible floor lines??
CND1
Thank you for the tip.
I tried this before, and the entire floor disappeared (and was unable to see the balcony floor)  I will check again to see if I missed something.  Thank you much.
CND
Mon, May 21, 2007 at 4:07:56 PM | Visible floor lines??
TJKENNEDY
3 Stars: 2 Votes
If you need to see some floor slabs, then you will have to leave floors turned on. If it is only a few lines in your elevation that you dont want to see you can use the linework tool to make them invisible.
Mon, May 21, 2007 at 6:35:02 PM | Visible floor lines??
puzzle
4 Stars: 10 Votes
Draw the floor so it lines up with the inside or middle of your wall. This way you won't have to turn anything off. I know this is not the correct way to build the floor but The only area that you will see the floor is in a section and that can be redrawn using 2d elements.
Macca
Sunshine Coast
QLD Australia
Mon, May 21, 2007 at 6:47:34 PM | Visible floor lines??
CND1
Puzzle
At this time, this seems to be the most appropiate solution.  Although I would need to adjust my sections to read correctly (platform framing used).
Thanks just the same.
Tue, May 22, 2007 at 5:51:14 PM | Visible floor lines??
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
If you use the paint tool you can paint the edge of the slab the same as the wall material.  Then use join geometry with the walls and the lines will clean up.
Regards,
Chris.
Tue, May 22, 2007 at 6:11:03 PM | Visible floor lines??
CND1
Mr. Spot.
This is a wonderful solution.
I cant wait to try it out.
I will let you know.
Thank you very much.
CND
drawing lines over a tike floor
Mon, Mar 30, 2009 at 5:21:15 PM
Hide door swings which are visible from floor below
Wed, May 6, 2015 at 12:16:03 PM
Stair visible through floor
Thu, Feb 5, 2009 at 5:21:21 PM
Floor Slab not visible in Plan!
Tue, Nov 9, 2010 at 1:58:17 PM
Walls and floors not showing up on other levels
Sun, Feb 17, 2013 at 5:39:01 AM
Page generation time: 3.8678
