Forums >> Revit Building >> Technical Support >> Fill Patterns
Mon, May 21, 2007 at 2:49:36 PM | Fill Patterns
terealva
Is it possible to create a fill pattern that looks like the pattern I've attached? If so, how can that be created?
Thanks,Terealva
Mon, May 21, 2007 at 5:46:49 PM | Fill Patterns
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Purchase and use HatchKit to create custom patterns.
Regards,
Chris.
Wed, Jul 25, 2007 at 8:50:41 AM | Fill Patterns
MJonesShaun
There has to be another way?
Wed, Jul 25, 2007 at 9:50:44 AM | Fill Patterns
There is another way. AutoCAD hatch patterns are described in a txt file by telling the pen when to write and in what direction. Below is a standard description.
*AR-B816, 8x16 Block elevation stretcher bond
0, 0,0, 0,8
90, 0,0, 8,8, 8,-8
If you can learn this process, you could write your hatch file pattern or perhaps you can find someone to do this for you. Obviously there is a cost one way or another.
Edited on: Wed, Jul 25, 2007 at 9:51:28 AM
Perpsective Fill Patterns
Mon, May 10, 2010 at 6:12:50 PM
Fill Patterns
Mon, Mar 10, 2008 at 6:40:09 AM
create/ convert hatch patterns (.pat) to revit fill patterns
Tue, Jun 2, 2015 at 11:29:00 AM
Fill patterns, where are they?
Tue, Mar 31, 2009 at 10:11:29 AM
Wall Fill Pattern question
Tue, Oct 23, 2012 at 8:39:37 AM
Page generation time: 0.7234
