18 Users Online (16 Members):
Forums >> Community >> The Studio >> Need a brick arch for rendering. Any suggestions or sources?
I need the arch to be made up of brick soldiers that radiate around the arch radius center point. Would making a sweep using a brick soldier pattern work? Can you apply a sweep in a curve at an elevation and expect the soldier to stay perpindicular to one edge of the sweep? Sounds like too much for accurender.
18 Posts No Rating |
it sounds to me like the answer is not in textures (though one could create a new texture that would apply....it might not be worth the trouble). try creating a brick family that has the approriate texture. then, in your project, array the new brick family around the arch. if the geometric distinction is not enough for your render, you can then create a sweep aroung the arch that would represent the mortar, and texture appropriately.
im sure there is a better, more efficient way, but this method has worked for me before.
let me know if it works for you, and good luck.
136 Posts No Rating |
Try the family here: http://essentialbim.com/product/brick-arch/
It works a treat and is very flexible and easy to align to your window width, you can also adjust lots of parameters to get the look you want.
Edited on: Wed, Jan 22, 2014 at 5:36:11 AM
For Architectural Services visit www.jrpcad.co.uk |
Brick Arch Around Window |
Sun, May 3, 2009 at 6:21:15 AM
Brick Arch Family - Do you have one?? |
Tue, Apr 12, 2016 at 10:35:54 AM
Rendering light sources within a custom curtain wall panel |
Mon, Sep 26, 2011 at 2:59:09 PM
Window with different head height on inside and outside |
Wed, Sep 3, 2008 at 11:59:16 AM
Flat (Jack) Arch w/ Keystone 2008 |
Mon, Mar 17, 2008 at 4:08:40 PM
