Forums >> Revit Building >> Technical Support >> watermark back ground on title block sheet.
Thu, Dec 18, 2003 at 10:44:29 AM | watermark back ground on title block sheet.
Bimman
Bimman Avatar
1 Stars: 2 Votes
On our titleblolck there is a watermark under the drawing info to help reduce theft of plans in the field. my question is this. I have the line weight set to a light grey color so it is not as dark as the drawing info itself, inorder to lessen confusion with reading the prints. On screen the watermark is shown correctly lighter than the rest of the informaiton. But when I print it out, it is a black line not lite grey as shown on screen. is there a printer driver I need to set or a setting I am overlooking. If any one has had this problem your ideas and fix would be appreciated.
Thu, Dec 18, 2003 at 11:48:01 AM | RE: watermark back ground on title block sheet.
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
most likely if it shows up correct on your screen, that is the way it's supposed to plot if your printer settings are correct. Try printing to pdf and see if it comes out correctly.
Hiroshi Jacobs
Thu, Dec 18, 2003 at 12:13:47 PM | RE: watermark back ground on title block sheet.
Bimman
Bimman Avatar
1 Stars: 2 Votes
just tried it, I got the same result using the pdf writer. This has had me boggled for some time now and really is my last wall to climb before I to start turning product out in revit.
Thu, Dec 18, 2003 at 12:20:22 PM | RE: watermark back ground on title block sheet.
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
when you go to print, in the lower right corner there's a button named "setup". Click the button and it will take you to the print setup box. Under appearance, make sure your "number of colors" isn't black and white.
Thu, Dec 18, 2003 at 12:31:05 PM | RE: watermark back ground on title block sheet.
Bimman
Bimman Avatar
1 Stars: 2 Votes
I feel little embarrassed. I was over looking that choice for, I don't want to say how long. Thanks for your help. Pete
Thu, Dec 18, 2003 at 12:36:29 PM | RE: watermark back ground on title block sheet.
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
lol, it happens to the best of us. Glad I could help.
Hiroshi Jacobs
How to link a Revision Schedule on Title sheet with Title Block
Fri, Jan 11, 2013 at 7:26:26 AM
Font on Title sheet absent from project Title Block
Thu, Sep 15, 2022 at 12:31:26 PM
watermark to pdf plot
Mon, Aug 15, 2011 at 7:18:30 AM
Title Block Labels
Wed, Feb 14, 2007 at 11:52:49 AM
Title Sheet text sent to back? or transparent?
Wed, Mar 4, 2015 at 3:25:00 PM
Page generation time: 0.4439
