Forums >> Revit Building >> Technical Support >> I SEE 1ST FLOOR FROM 2ND FLOOR PLAN...WHY IS THAT?
Fri, May 18, 2007 at 5:17:16 PM | I SEE 1ST FLOOR FROM 2ND FLOOR PLAN...WHY IS THAT?
chilenito
For some reason When I double click on the second floor plan, I see the first floor plan. How can i fix this?
Matias Santini
Fri, May 18, 2007 at 5:27:33 PM | I SEE 1ST FLOOR FROM 2ND FLOOR PLAN...WHY IS THAT?
chilenito
I just noted that some walls are unconnected on the top constrain.....but no matter if I change it to the second floor, still having the same issue.
Matias Santini
Fri, May 18, 2007 at 5:30:21 PM | I SEE 1ST FLOOR FROM 2ND FLOOR PLAN...WHY IS THAT?
coreed
coreed Avatar
4 Stars: 16 Votes
the first thing to check is the properties for the view and set the Underlay to "none"
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Fri, May 18, 2007 at 6:00:15 PM | I SEE 1ST FLOOR FROM 2ND FLOOR PLAN...WHY IS THAT?
chilenito
THANKS!!!
Matias Santini
Tue, May 29, 2007 at 1:18:14 PM | I SEE 1ST FLOOR FROM 2ND FLOOR PLAN...WHY IS THAT?
dingo
thanks!!! this helped me too!! it was driving me crazy.
Tue, May 29, 2007 at 1:33:49 PM | I SEE 1ST FLOOR FROM 2ND FLOOR PLAN...WHY IS THAT?
chilenito
I had the same issue last week and I had to re-draw the wall showing on the socnod floor. now I know.......hehe
Matias Santini
1st floor to 2nd floor
Sat, Apr 7, 2012 at 10:01:20 AM
Display Room Names for Double Volume Spaces on 2nd Floor Plan
Mon, Mar 18, 2013 at 10:46:29 AM
2nd flr walls not lining up with first floor walls
Wed, Jun 16, 2010 at 2:20:42 PM
my 1st floor plan has not detail
Fri, Nov 23, 2007 at 10:33:32 AM
Show above floor plumbing on 1st floor Framing
Tue, Feb 19, 2008 at 3:29:38 PM
Page generation time: 0.5110
