Forums >> Community >> Newbies >> Room tags At Sections
Fri, May 18, 2007 at 10:57:11 AM | Room tags At Sections
Lole
I'm having some problems with the room tags at the sections.I located them at the sections, and everytime that I saved to central the room tags fell down and did not recognize the room.Do you know how to fix this?Thanks,
Fri, May 18, 2007 at 11:34:45 AM | Room tags At Sections
dano3d
3.5 Stars: 3 Votes
I don't have a solution for you.
Just wanted to let you know you're not the only person experiencing this problem.
Maybe someone out there can help us... PLEASE.
Thanks
Wed, May 23, 2007 at 8:43:49 AM | Room tags At Sections
rkitect
rkitect Avatar
4 Stars: 29 Votes
I am not experiencing this problem, but I may not be emulating the scenario correctly.  Elaborate a little for us:
Are you having problems placing Room Tags in a plan view near Section Cuts or placing Room Tags on a section view?  Are the sections building sections, wall sections, section callouts?  This may help us understand a bit better what's going on.
Also, what version of revit are you using?
Thanks!
Thu, May 24, 2007 at 7:37:20 AM | Room tags At Sections
Lole
I'm having problems placing room tags on sections and wall sections views. I'm using Revit 9.1.
Thanks!
Thu, May 24, 2007 at 9:17:33 AM | Room tags At Sections
rkitect
rkitect Avatar
4 Stars: 29 Votes
This works fine in RA2008.  I don't recall ever doing it in 9.1 so I'm not sure if it's a version difference.  Seems like it would be able to though, that's a fairly basic function.  When I did place the Room Tag in the section view, it did center it to the room, which was outside of the cropped region of the view.  So I had to reposition the tag so it was visible.
 I would also check to see if you have the Room Tags turned of in the Visibility Graphics dialogue.  These are the only things I can think of.  Sorry I couldn't help more Sad
Thu, May 24, 2007 at 5:51:19 PM | Room tags At Sections
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I seemed to recall this being a bug that was fixed in RAC2008.
Regards,
Chris.
Tue, Jun 12, 2007 at 2:46:10 PM | Room tags At Sections
OPIE
WE HAVE HAD THE SAME PROBLEM WITH THE TAGS FALLING OUT OF SECTIONS, THEY FALL TO ELEV 0'-0"
WE NEVER DID FIGURE OUT HOW TO KEEP THEM FROM FALLING, WE JUST STOPPED PUTTING SMART ONES IN AND WENT BACK TO DUMB ONES. THEY STAY WHERE THEY ARE SUPPOSED TO.  WE JUST NOW SWITCHED OVER FROM 9.1 TO RAC2008 AND DONT HAVE ANY PROJECTS THAT FAR ALONG YET. SO I DONT KNOW IF IT HAS BEEN FIXED OR NOT
VERY FRUSTRATING.
Want to see Room Tags but not Rooms
Wed, Oct 5, 2016 at 11:37:51 PM
Room name in section
Fri, Aug 30, 2013 at 7:39:26 AM
ROOM TAGS
Fri, Jul 29, 2011 at 8:25:58 AM
Room tags in section views
Tue, Sep 27, 2005 at 4:39:14 PM
Room Names in Sections?
Mon, Nov 21, 2005 at 8:43:30 PM
Page generation time: 0.6269
