Forums >> Revit Building >> Technical Support >> Selecting Elements in Revit
Fri, May 18, 2007 at 8:41:32 AM | Selecting Elements in Revit
blake
3 Stars: 2 Votes
Is there a way to select all the elements in a specific view.  The Select All Instances chooses every element in your file.  There a time were I have multiply elements on one level that needs to change.  It would be nice to be able to grab them all quickly and change them.  I know with object you can Isolate Category and grab them all that way.  But with annotation you cannot always do that. Specifically I am talking about Room Tags.  I like to be able to change my room tag to show area when I am working but then I need to change them to just show the room number when I am done.  Well if I Select All Instances it changes the Room Tags in my presentation views that just say the room name.  So Right now I have to select each tag individually and change them and that is annoying when you have lots of rooms.  If I try Isolate Category it isolates the room and not the tag.
Back to my original question is there a way to only Select All Instances in view only.
Thanks for the help
Fri, May 18, 2007 at 9:00:36 AM | Selecting Elements in Revit
coreed
coreed Avatar
4 Stars: 16 Votes
select all the elements and then use the filter button in the options bar to remove un-wanted elements
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Fri, May 18, 2007 at 9:07:32 AM | Selecting Elements in Revit
blake
3 Stars: 2 Votes
Thanks alot I have been using Revit for awhile now and have not paid any attention to that button.
Grouped elements not selecting
Fri, May 22, 2009 at 1:23:14 PM
2015: selecting elements in link
Tue, Nov 18, 2014 at 1:17:26 PM
12
Selecting all elements
Mon, Dec 19, 2005 at 5:36:24 PM
Selecting-De-selecting objects.
Fri, Nov 25, 2005 at 10:12:01 PM
Elements don't appear highlighted when selected...always need to refresh!!
Thu, Jun 30, 2011 at 6:03:51 AM
Page generation time: 3.9844
