Forums >> Revit Building >> Technical Support >> Diminsion under dim line
Thu, May 17, 2007 at 2:18:16 PM | Diminsion under dim line
hippy
This has to be so simple it is killing me. I need a dim style with the text below the dim line or even without a dim line but below the tics. Just having a rough day. Thanks
Thu, May 17, 2007 at 9:27:17 PM | Diminsion under dim line
framerman
4 Stars: 13 Votes
Don't think you can have a default dimension style do this. It's the little blue grabby thing to just drag the dimension down to where you need it. Select the dimension in question and it will show. I hope you need just one or two and not the whole set of prints.
Thu, May 17, 2007 at 9:39:54 PM | Diminsion under dim line
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Revit will not allow you to put you text below the dim line by default.  Each dimension would need to modified and the text relocated to below the line.
 I'm interested as to where it is convention to have the text below the line?  I haven't heard someone request this before.
Regards,
Chris.
Fri, May 18, 2007 at 10:10:30 AM | Diminsion under dim line
hippy
I am cutting up huge buildings into 5' by 5' squares or 10' by 10' etc..for storage units. I hide dim lines on center walls and pull each diminsion into the corrasponding room thus half my dims are below the dim line which I would prefer to delete anyhow.  Thanks anyhow I have a wish list as big as Revit already is.
3d dim
Mon, Jun 16, 2008 at 4:09:16 PM
Dimensioning an Ellipse?
Thu, Jan 24, 2008 at 12:57:00 PM
Settings for stringer
Thu, Oct 3, 2013 at 7:53:55 AM
Dim. lines
Wed, Jan 3, 2007 at 3:45:57 PM
Temp Dim's are too small
Mon, Jul 30, 2007 at 10:36:05 PM
Page generation time: 3.4227
