Forums >> Revit Building >> Technical Support >> Linked File vs group
Thu, May 17, 2007 at 9:27:20 AM | Linked File vs group
mezdez24
4.5 Stars: 3 Votes
I’m working on a hospital project and have a question on what’s the best practice of putting together multiple patient rooms together. I was thinking of creating a linked file and then inserting into our revit file. I also thought about creating a group and copying it. Do you have any suggestions? I’m also working in the new Revit Architecture 2008.
Thanks in advance!
Thu, May 17, 2007 at 10:33:28 PM | Linked File vs group
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I'd imagine groups would probably make more sense as you'll be able to exclude overlapping walls etc from them...
However, in 2008 its not that big of a deal as Groups and Links in revit are virtually interchangeable.
Regards,
Chris.
Fri, May 18, 2007 at 11:50:26 AM | Linked File vs group
mezdez24
4.5 Stars: 3 Votes
Thanks! Yeah, I have been messing around with the groups and links and reading up on everything you can do with them. Thanks for the response!
Linked file model missing attached detail group
Mon, Aug 17, 2009 at 8:26:38 AM
Switching off group Revit 9.1
Thu, Jun 21, 2007 at 6:56:19 AM
INSERTED GROUP - COPIED GROUP - DIFFERENT RESULT [ 1 2 ]
Wed, Nov 23, 2016 at 3:27:29 PM
15
Linked Revit Topography file displayed in hidden lines in 3d view main bld file
Sat, Jul 7, 2012 at 3:38:16 PM
Linked File, how can I dimension it?
Sun, Dec 19, 2010 at 8:08:50 PM
Page generation time: 1.9129
