Forums >> Revit Building >> Technical Support >> dependent views
Thu, May 17, 2007 at 6:30:45 AM | dependent views
Marc9999
hi,
I'm using Revit Architecture 2008.  Does anyone know of a method when using dependent views to show all items outside of the crop region ie dimensions?  Revit seems to not display dimensions which are not completely within the crop region.  I have toggled on and off the annotation crop but this appears to make little difference.
many thanks
 Marc
Fri, May 18, 2007 at 9:55:56 AM | dependent views
rkitect
rkitect Avatar
4 Stars: 29 Votes
Since dimensions are view specific, have you tried re-dimensioning the dimensions you need show?  Is there more than just dimensions you need shown here?
Thu, Sep 6, 2007 at 9:35:13 AM | dependent views
wallrus
you need to readjust the annotation crop region. This is separate from the model crop region. Just grab the annotation crop box and stretch it to where you need it to be to show the dimensions.
Dependent views not the same as Parent view...
Fri, Jun 16, 2017 at 11:02:18 AM
Detail Callout Bubbles and Dependent Views
Thu, Aug 12, 2010 at 6:51:10 AM
Design options and dependent views?
Wed, Nov 4, 2009 at 8:26:39 AM
filled region in dependent views
Fri, Feb 22, 2008 at 6:53:39 AM
Collaboration and dependent views
Fri, Jun 9, 2017 at 10:14:43 AM
Page generation time: 0.1952
