Forums >> Revit Building >> Tips & Tricks >> Bathtub decks
Wed, May 16, 2007 at 4:18:55 PM | Bathtub decks
mongopac
For large bathtubs that are deck mounted, I've been using the stair command to create the deck and its worked pretty well, but I don't know,  it feels so "workaround-ish" to me to do it that way, so I was just wondering if anyone in RevitLand had figured out anything better.
Fri, May 18, 2007 at 9:59:16 AM | Bathtub decks
rkitect
rkitect Avatar
4 Stars: 29 Votes
Seems to me you would build it in Revit the way you would in real life: walls to a certain height with a horizontal surface (ie: floor?).  Another option is just modeling the deck as a in-place family as it is a custom piece.
HTH.
Stairs & Decks
Wed, Aug 1, 2007 at 5:00:33 PM
Problem with adding a material to this bathtub
Fri, Oct 12, 2012 at 1:06:41 PM
decks
Sat, Nov 20, 2010 at 10:26:07 AM
Wall Finish in upper face
Tue, Aug 14, 2012 at 12:12:30 PM
Lattice Under Decks
Thu, Apr 10, 2008 at 9:47:32 AM
Page generation time: 0.0183
