Forums >> General Discussion >> Revit Project Management >> Fill Patterns
Wed, May 16, 2007 at 11:43:35 AM | Fill Patterns
terealva
Hi,
I'm working on exterior elevations and I want to show panels on my walls. I created a wall type that has panels as an exterior finish. Is there a way to manipulate the fill pattern so that I have control on where the panels should start and so on?
Thanks,
Terealva
Wed, May 16, 2007 at 12:33:47 PM | Fill Patterns
TomDorner
4.5 Stars: 25 Votes
Model patterns can be moved or aligned into position.
Drafting patterns do not have this option.
Tom
Wed, May 16, 2007 at 3:09:56 PM | Fill Patterns
terealva
Could you pleasegive me some guidance on how to do that?Thanks,Terealva
Wed, May 16, 2007 at 3:32:37 PM | Fill Patterns
ArchWestCY
4.5 Stars: 7 Votes
I assume that you have a pattern that looks like the panels you want.  Then in the view, just select one of the model lines and move it.  You can also use the align tool to line your pattern up with the edge of the wall, or anything else.
ArchWestCY
Wed, May 16, 2007 at 3:39:44 PM | Fill Patterns
terealva
So, can I manipulate fill patterns if they are part of my wall types?
Terealva.
Wed, May 16, 2007 at 3:42:19 PM | Fill Patterns
ArchWestCY
4.5 Stars: 7 Votes
Sure.  Just try.  This is really important with masonry walls.  When you want your coursing to line up.  Ceiling grids work the same way.  Just get in there and move some hatch around, it won't bite.
ArchWestCY
Wed, May 16, 2007 at 5:52:58 PM | Fill Patterns
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Hover your mouse over one of the fill pattern lines in elevation or 3D, Use your TAB key until the line is highlighted.  You can now move this line or rotate it as necessary.
HTH.
Regards,
Chris.
Perpsective Fill Patterns
Mon, May 10, 2010 at 6:12:50 PM
Fill Patterns
Mon, Mar 10, 2008 at 6:40:09 AM
create/ convert hatch patterns (.pat) to revit fill patterns
Tue, Jun 2, 2015 at 11:29:00 AM
Fill patterns, where are they?
Tue, Mar 31, 2009 at 10:11:29 AM
Wall Fill Pattern question
Tue, Oct 23, 2012 at 8:39:37 AM
Page generation time: 1.1349
