11 Users Online (9 Members):
Forums >> Revit Systems >> Technical Support >> Ceiling plan view... No Doors?
8 Posts No Rating |
I have a question for you guys... When I view the arch's building with its own ceiling plan view, no doors are present in that view. How do I get the doors to show up when I work and print? Any help would be great.
have you tried using the visablity settings? also you could check the view depth and that.
----------------------------------- My Futurama Fan Fiction 'Hammer087' - http://futurama-madhouse.com.ar/fanfic/indexh.shtml#hammer087 |
Go to view properties and change the cut plane settings so that the cut plane is cutting your doors (I think the default is 7'-6" you might change it to 4' or something like that.
1 Posts No Rating |
If you want to still see the door openings (i.e. to be able to see the DOOR HEAD) you can just turn off the door panel and plan swing symbology in the Visibility Settings. Go to View Properties/Visibility1 expand the DOORS category2 uncleck PANEL & PANEL SWING boxes.3 DONE! Hope this helps, Ron
Problem seeing doors in reflected ceiling plan |
Mon, Jul 14, 2008 at 9:26:12 AM
new user question on ceiling plan view |
Fri, Feb 16, 2007 at 7:31:49 PM
Ceiling View Ranges: 2 |
Sat, Feb 23, 2008 at 9:25:24 PM
Coloring elements - plan view |
Sun, May 28, 2006 at 2:13:39 AM
How to make a floor plan level into a ceiling level plan in Revit MEP |
Tue, Apr 12, 2011 at 7:09:06 AM
