Forums >> Community >> Newbies >> WINDOW FAMILIES
Tue, May 15, 2007 at 3:08:44 PM | WINDOW FAMILIES
whit25
I am trying to start a new window family with a triple casement window. Currently I have a double casement window that i am trying to edit, but it's not working as easily as i thought. can i insert CAD details and extrude those or no? could someone please give me some guidance as to how to start this?? thanks!
Tue, May 15, 2007 at 3:43:22 PM | WINDOW FAMILIES
TomDorner
4.5 Stars: 25 Votes
Windows are one of the most complex families to make.  If yu are new to Revit it is best to find contnet made by someone else and use that until you gain a deeper understanding of Revit and the family editor.  Autodeskhas a number of triple casements on the Revit Web Library.
http://revit.autodesk.com/library/html/index.html
When you are loading a family click on the Web Library icon to get there from the load family dialog box.
For family tutorials check out this site, and www.dgcad.com
Tom
www.reviteer.com   http://twitter.com/Reviteer
Tue, May 15, 2007 at 4:53:43 PM | WINDOW FAMILIES
whit25
thanks for the website...you think i could edit families more easily from there? i've been trying to figure out the windows all afternoon, haha!
Thu, May 24, 2007 at 9:27:48 AM | WINDOW FAMILIES
Bosque
Hey there, I'm not making a post to help you out, but it is related to windows. I have also played about with windows for a few hours but cannot manage to edit them, but I was wandering whether its easy to change the materials, does it depend on the window I'm editing?. Can anyone explain how to do that in less than 3 lines? Thanks in advance!
 S. Fisher
Thu, May 24, 2007 at 3:44:50 PM | WINDOW FAMILIES
framerman
4 Stars: 13 Votes
hopefully, your window in question has subcategories. Then in your project, you can just assign materials to your subcategories under Settings>Object Styles. You wouldn't need to edit your family at all.
Otherwise, make your own subcategories in your family under Settings>Object Styles.
THEN select your geometry you want to assign materials to and select the proper subcategory under properties.
This is the proper way to do it in my opinion, but you can also just select the geometry in your family editor, go to the properties, make sure there's no subcategories and assign a material to it.
Your subcategories make your family a more powerful tool. It makes it easier to change all these settings.
I know, not less than 3 lines LOL.
Thu, May 24, 2007 at 5:03:30 PM | WINDOW FAMILIES
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I would disagree with this as the "proper way".
Best way is (IMHO):
Select the Solid in the family you want to assign the material to.
Go to its properties and next to the material parameter there is a grey box to the far right.  Click it
You are now given a window to select a parameter for this material.  If you don't have one, click add a parameter and name it appropriately.
Now you'll easily be able to change this elements materials from in the project by go to the elements type properties or if you made it an instance, its instance parameters.
HTH.
Regards,
Chris.
Thu, May 24, 2007 at 5:46:09 PM | WINDOW FAMILIES
framerman
4 Stars: 13 Votes
owned by Mr. Spot! LOL, you are right I should have said a GOOD way, but not the only way. Material parameters are a great way to do this and better.
window families
Mon, Nov 28, 2005 at 6:43:56 PM
Better Window Families
Tue, Aug 30, 2005 at 4:25:33 PM
Curtain Walls vs Window Families
Tue, Sep 13, 2016 at 7:14:41 AM
Fleetwood window families unable to offset form exterior
Tue, Oct 18, 2016 at 10:24:42 AM
Nested window mullions (Generic Models) don't appear in Window Schedule
Wed, Apr 30, 2008 at 11:33:20 AM
Page generation time: 6.5796
