Forums >> Revit Building >> Technical Support >> Lost Import
Tue, May 15, 2007 at 11:41:55 AM | Lost Import
n8dogg
Sometimes if an imported file (cad) is not linked (current view only) it can easily become lost when that particular view is deleted or its visibilty midified.  the instance is still int the system yet its difficult to find if you dont know where it was originally placed.  Is there an easy way to locate an imported instance so it can be deleted?  No options are available form manage links or visibility/graphics to select the instance in question (as far as i can tell).  thanks
Wed, May 16, 2007 at 8:26:13 AM | Lost Import
rkitect
rkitect Avatar
4 Stars: 29 Votes
This is where it is good to know what version you are using.  In Revit Architect 2008 you can just right click on the link in the Project Browser and 'Select All Instances' to have it highlight.
In anything earlier, I never knew of a way to locate links once they were in a view.  If I lost one, I just deleted it and made sure I selected manual placement next time so I know where it goes.
Good luck and let us know what you find.
Import SAT file
Fri, Nov 30, 2012 at 9:42:19 AM
import to revit from autocad
Sun, Mar 31, 2013 at 11:37:12 AM
LOst Title shhet
Fri, Nov 13, 2015 at 4:08:01 PM
recovering lost files
Tue, Sep 2, 2014 at 1:28:11 PM
Importing SAT files
Tue, May 22, 2007 at 9:09:20 PM
Page generation time: 0.1455
