Forums >> Community >> Newbies >> tiles
Tue, May 15, 2007 at 1:05:38 AM | tiles
Dewy
How do u make tiles larger? i have tried everything.
Tue, May 15, 2007 at 5:50:32 PM | tiles
framerman
4 Stars: 13 Votes
There are a few different type of tiles. If you could be more specific, I'm sure you could get an easy answer quickly.
Tue, May 15, 2007 at 7:28:01 PM | tiles
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Are you talking rendering or fill patterns?
Regards,
Chris.
Mon, Aug 22, 2011 at 11:58:10 AM | larger tiles
dreamwater001
Im having the same difficulty. I'm trying to create larger tiles that will show up in renderings. Similar to this image:
Mon, Aug 22, 2011 at 12:16:04 PM | tiles
Those are not tiles ... they appear to be metal panels.  You can use a curtain wall to create something like tis with the "tiles" being the CW panels.... just assign an appropriate material to the panel.
Or this could be a wall material pattern with the "tile" material assigned at a larger scale.
Edited on: Mon, Aug 22, 2011 at 12:17:06 PM
3D Roof Tiles for temple
Sat, May 15, 2010 at 6:55:41 AM
Scheduling # of Floor Tiles
Thu, Oct 6, 2011 at 6:51:01 PM
tiles 3d on the roof
Fri, Feb 23, 2018 at 10:45:21 PM
ROOF TILES
Fri, Feb 23, 2018 at 10:52:53 PM
Ridge Tiles
Wed, Mar 14, 2007 at 7:49:47 AM
Page generation time: 4.0977
