28 Users Online (26 Members):
Forums >> Revit Systems >> Technical Support >> Rotating Drawing Title on Sheet
I needed to rotate a view on a sheet, but the tag stays attached and rotates with it. How can I rotate the drawting tag seperately? Thanks Rae
this was posted by Mr. Spot in a previous posting, sounds like what you want to do "EASIEST WAY: PLACE VIEW ON SHEET. ACTIVATE THE VIEW. SELECT THE CROP REGION. ROTATE THE DESIRED AMOUNT. NOTE THE VIEW ROTATES AND THE CROP REGION REMAINS THE SAME. THIS ALLOWS YOUR VIEW TITLE TO REMAIN HORIZONTAL." HTH
2 years after you posted it... brilliant!
50 Posts No Rating |
Good thing you posted SteveB... I just learned something new. Mucho Thanks!!!
the "search forums" function finds all kinds of good stuff.
Rotating Views on Sheet |
Tue, Jan 19, 2010 at 12:30:55 PM
Rotating Views On a Sheet [ 1 2 ] |
Tue, Jun 17, 2008 at 12:49:46 AM
18
Rotating Viewports without rotating title |
Wed, Apr 22, 2009 at 10:52:58 PM
Sheet´s Tags |
Tue, Jun 19, 2007 at 2:17:32 PM
How to link a Revision Schedule on Title sheet with Title Block |
Fri, Jan 11, 2013 at 7:26:26 AM
