Forums >> Revit Building >> Technical Support >> Changing color and texture on a user created model
Wed, May 9, 2007 at 2:18:35 PM | Changing color and texture on a user created model
Tcanuth
I created a basic model in revit using the create tool and i cant seem to cahnge it from the basic gray. Any ideas on how to get it to change?
Thu, May 10, 2007 at 8:49:59 AM | Changing color and texture on a user created model
rkitect
rkitect Avatar
4 Stars: 29 Votes
Do you mean using the "Create Mass" tool?
I think the quickest way would be to use the paint bucket tool and select a material from the drop down box.
Edited on: Thu, May 10, 2007 at 8:50:07 AM
Thu, May 10, 2007 at 1:02:23 PM | Changing color and texture on a user created model
Tcanuth
i would have thought the paint bucket would have done it as well, but it doesnt seem to get the job done. What i did was i used the modelling tab and i clicked create... and selected a family, not sure what family i had selected, and clicked solid form, which allowed me to draw and extrude any shapes i wanted to make myself, and after finishing it i found i cannot change it from the basic gray. Hopefully this will help because i have no idea what to do about it.
Thu, May 10, 2007 at 1:27:52 PM | Changing color and texture on a user created model
archdan
3.5 Stars: 2 Votes
You created an in-place family, which behaves like other families, in that you cannot paint any surfaces without editing the family.  Select the object click edit and now you can paint individual faces or assign a material to each geometry extruded.
Fri, May 11, 2007 at 12:44:44 PM | Changing color and texture on a user created model
rkitect
rkitect Avatar
4 Stars: 29 Votes
I C WAT U DID THAR!
I thought you were talking about a massing model!  Yes, if you click on the family, then select 'Edit Family' you will be able to change the materials of the family.  Although, I think you should be able to use the paint bucket still.
What version of Revit are you using Tcanuth?
Got a problem with texture orienting from a imported revit model in 3DS MAX 2008
Tue, Mar 31, 2009 at 10:15:40 AM
CHanging color of walls/roofs
Tue, Oct 31, 2006 at 8:54:31 AM
making glass a translucent color
Sun, Apr 30, 2006 at 3:42:20 AM
Texture patterns render black
Thu, Apr 14, 2011 at 9:14:44 AM
12
Texture behaviour with new family from imported 3D object
Tue, Sep 27, 2016 at 6:58:11 AM
11
Page generation time: 3.3762
