15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> Import line weights from DWG?
6 Posts No Rating |
I have some sections I am linking into a Revit project... however, the lineweights are not coming in with the project. I have found that I should import the lineweights. I want to apply the AIA standard lineweights that Revit already has a setup for... once I go to the import settings/ import line weights how do I get these to work in the Revit project? I am missing one simple step I am sure... please help
Simply assign the lineweight you want to the color number of the imported file. Note that if the lines or layers are set to lineweight by entity or if the layer lineweight is not set to default, this will not work.
How to match .CTB line weights with Revit |
Fri, Dec 5, 2008 at 4:11:55 PM
Import & Export Line Weights - setting them |
Fri, Apr 1, 2011 at 12:45:54 PM
Export to dwg - Line weights |
Mon, Oct 23, 2006 at 2:35:25 AM
Line weights reverting to standard |
Thu, Jan 6, 2011 at 7:10:38 AM
Revit Structure Questions Line Weights |
Wed, Jan 16, 2013 at 3:33:32 PM
