Forums >> Revit Building >> Technical Support >> How to make section marks smaller?
Wed, May 9, 2007 at 9:55:58 AM | How to make section marks smaller?
archuk15
Hello all, I am creating a floor plan and adding my wall section markers.  They are larger than we use here in the office and I was wondering how to change the size of the section mark.  I have already gone into the annotation family and created a new section head to the correct size... now how do I apply my new section head to the section marks existing in my project?
Wed, May 9, 2007 at 4:47:08 PM | How to make section marks smaller?
ArchWestCY
4.5 Stars: 7 Votes
Once the new tag is loaded into the project, you need to tell Revit to use it.  Go to the Settings menu.  Then, down to View Tags, and over to Section Tags.  You will get a dialog box for the Section Tags.  The top line is Section Heads.  Click in the right side of this field and you will get a drop down where you should find your new Section Head listed.  Click OK, and all of you existing tags should update.  Callouts and Elevation Tags are edited in the same way.
ArchWestCY
section marks
Tue, May 17, 2005 at 12:54:13 AM
Section marks appearing on plans
Thu, Dec 6, 2012 at 4:26:26 AM
Section marks w/ SIM
Thu, Oct 8, 2015 at 8:03:54 AM
13
Section Marks in Revit
Wed, Feb 4, 2009 at 10:29:54 AM
"Referenced From" Issue with Section Marks
Mon, Feb 6, 2012 at 2:55:01 PM
Page generation time: 1.8175
