Forums >> Revit Building >> Technical Support >> window and door legend
Tue, May 8, 2007 at 5:14:41 PM | window and door legend
Kartyh
I appoligize if this has already been answered, I looked but could not find the answer. I have created a legend view that I am using for by door types. I created one legend for all the doors. What I need to be able to do is tag the doors using a tag that conveys the correct number. I could use a "dumb" tag that can be manually updated for each door but this seems counter "revit". Any help would greatly be appreciated.
Thu, May 10, 2007 at 9:16:26 AM | window and door legend
rkitect
rkitect Avatar
4 Stars: 29 Votes
Usually, it works the other way around: you tag the doors, then create the schedule.  You can then select all the doors that you want to be tagged a certain number and change their 'Type Mark' to the number you want.  The schedule should change accordingly.
As far as getting the doors to tag 'correctly' according to your legend, you can try this (but be ready to Undo the operation if it produces undesired effects):
 Select all the doors you want tagged as 'Door A'.  In the 'Mark' parameter, enter 'Door A' (or whatever  you want it to be tagged as.  Preferably according to your legend Smile).  Hit 'OK'.  It will probably fuss at you for having duplicate marks, but that's the way you're doing things so tell it to hush and check to see if that's what you wanted.
In the future I would really look at doing it the other way since it makes it much easier when you change a door type or decide this door needs to be Type B instead of Type D.
Let me know if this is what you were looking for.  Good luck!
Placing a Window in a Legend
Thu, Nov 10, 2005 at 6:53:25 PM
Window Legends-showing nested components
Thu, Mar 20, 2008 at 4:20:36 PM
Legends for creating window or door schedules
Thu, May 29, 2008 at 11:18:05 AM
Window & Door Legends
Thu, Sep 10, 2015 at 12:41:54 AM
Window legends
Fri, Dec 31, 2004 at 8:35:39 AM
Page generation time: 0.3492
