Forums >> Revit Building >> Technical Support >> Transfering door and window tags to Sheet File
Tue, May 8, 2007 at 2:13:35 AM | Transfering door and window tags to Sheet File
Mogee
Hi,
 I am currently working on a local file which i have updated with window and door tags. In a sheet file the building has updated the windows and doors and now I want to show the tags in the sheet file. I looked under avisibility properties and all the icons are checked and the building that appears in the sheet file is similar to how an Xref would look like in AutoCAD.
How would I show the tags in the sheet file?
 Regards
Mogee
Door and window tags
Thu, Nov 3, 2011 at 8:51:34 AM
Transfering sheet set-up
Fri, Mar 28, 2008 at 6:46:41 AM
Room Window and Door Tags
Thu, Nov 15, 2007 at 9:21:10 PM
Can I export a 3D revit file(fbx,obj,etc) with annotations(door/window tags)?
Thu, Oct 1, 2020 at 2:35:40 AM
Deleted dimensions, door tags and window tags
Wed, Jul 18, 2007 at 10:57:29 AM
Page generation time: 3.1058
