Forums >> Revit Building >> Technical Support >> Stair Plan Enlargements
Sun, May 6, 2007 at 8:39:59 PM | Stair Plan Enlargements
Tmifsud
I'm curious as to what people have found as the best technique for creating stair plan enlargements.  I've found the appearance of stairs graphics in plan is different from those in enlargements created using detail callouts.   See attached images.  Can the graphics of the stair in detail callout view be changed to match those of the plan?  If so, please advise as I don't see how.  Are plan enlargments typically duplicate views with crop regions adjusted?
Thanks in advance.
Mon, May 7, 2007 at 6:33:41 AM | Stair Plan Enlargements
puzzle
4 Stars: 10 Votes
I have used both Callouts and Duplicating views. You can modify either to do the smae thing. It looks that in the image that is not showing part of the stairs, that you may have to change the view range in properties. Also have a look under stairs in visibility and make sure that Stairs beyond cut and Stringers beyond cut are ticked. All I can think of. Hope this helps.
Macca
Sunshine Coast
QLD Australia
PRECAST STAIR BEGIN WITH RISER LOOKS INCORRECT ON PLAN
Fri, Sep 2, 2016 at 7:03:03 AM
stair plan
Wed, Oct 26, 2011 at 12:31:01 PM
stair not showing up as it should be in plan region
Fri, Oct 30, 2009 at 11:46:34 AM
Plan Regions Cutting Stairs
Thu, May 26, 2011 at 6:14:12 PM
Can“t see entire stair
Fri, Sep 13, 2013 at 2:16:00 AM
Page generation time: 1.2111
