Forums >> Revit Building >> Technical Support >> Create a toposurface using imported files
Sat, May 5, 2007 at 2:16:55 PM | Create a toposurface using imported files
hawk8225
I am using Revit Building 9.1 App, and "Introducing and Implementing Autodesk Revit Building" book. I am teaching myself this program and have come up against a problem in the Chapter 3\Exercise 2\steps 2.6 and 2.7 when I try selecting the imported symbol when i select the USE IMPORTED tab. According to the book, after selecting the USE IMPORTED tab another window will open. This window is the "Add Points from Selected Layers". THIS WINDOW DOES NOT APPEAR WHEN I FOLLOW THE DIRECTIONS. Can someone help me overcome this issue? I sure would appericiate it.
Toposurface
Thu, May 3, 2007 at 2:50:42 PM
Toposurface and ACAD files
Tue, Nov 2, 2004 at 4:26:49 PM
Toposurface - selecting imported instance
Tue, Sep 4, 2007 at 12:20:56 AM
toposurface problem!!!
Fri, Nov 5, 2010 at 7:40:03 AM
Imported Toposurface
Sat, May 5, 2007 at 3:39:33 PM
Page generation time: 0.7065
