Forums >> Revit Building >> Technical Support >> What is de difference between "Void From" and "Properties>Identity data>Void&qu
Thu, May 3, 2007 at 3:46:46 PM | What is de difference between "Void From" and "Properties>Identity data>Void"
samov
What is de difference between "Void From" in the mass editor and "Properties>Identity data>Void" when right clicking on a mass object... ?!
and is there any way to mark a solid as a void and vice versa for use in substracting adding to a mass object??
thank you.
IFC export/import and "Identity Data"
Tue, Nov 5, 2013 at 6:04:10 PM
VOID FORM says there is no geometry to cut.... [ 1 2 ]
Wed, Dec 17, 2008 at 12:52:27 PM
19
Identity Data
Thu, Oct 6, 2005 at 10:21:03 PM
Void Masses
Fri, Oct 3, 2008 at 4:11:06 PM
"group parameter under" changed upon loading into project
Wed, Aug 11, 2021 at 3:16:03 PM
Page generation time: 0.7167
